Hi,
I found a dxf file online but I don’t have any cad software… could you help with transferring to pdf or svg?
骰塔1.4_3mm.dxf (145.5 KB)
It is from instructables.com
Hi,
I believe inkscape opens DXF files now, inkscape 1.09 handles that sort of thing a lot better than it used to.
I’ll pop it open and save it out as svg but you definitely can do it.
Hmm actually that gave an error. Something is amiss with that DXF that Inkscape doesn’t like.
There are online converters, if you google “DXF converter” you’ll find a lot of options.
Hmm cloudconvert failed too. This file is definitely screwed up.
Failing that, there are some great dice tower options in the Free Files area here.
Several: Search results for 'dice tower' - Glowforge Owners Forum
This is one of my favorite:
Thank you for the links… however I am looking for a design that I can use to resell… I beleive that complex one is not for commercial use
But yes any dice tower file I can use to modify (with logo or text that customer gives) and use to sell would be appreciated
You can not re-sell designs you download from Instructables (or Thingiverse, or here…)
If that is the case, you will need to make the design yourself, or purchase rights to one.
For Thingiverse and Instructables the uploader can choose which license to publish under, it’s possible the file OP posted has some commercial leeway.
True, but the default is no, and this particular design does not specify (I checked.)
I’m merely specifying as your statement made it sound like a hard no on all things Thingiverse/Instructables.
Inkscape says the following when I try to open it:
Traceback (most recent call last):
File "dxf_input.py", line 624, in <module>
DxfInput().run()
File "/Applications/Inkscape.app/Contents/Resources/share/inkscape/extensions/inkex/base.py", line 123, in run
self.save_raw(self.effect())
File "dxf_input.py", line 613, in effect
entities[entity]()
File "dxf_input.py", line 96, in export_POINT
generate_ellipse(vals[groups['10']][0], vals[groups['20']][0], w / 2, 0.0, 1.0, 0.0, 0.0)
NameError: name 'w' is not defined
Yes I scanned many models before finding this one where rights were open, that is why I had this one as test to cut but dxf seems corrupted so it looks like I am on my way trying to find one that has the proper rights to use for commercial use. If anyone has such a model please share with me
There are designers who sell patterns on Etsy that include commercial use rights.
