Can aura cut construction paper? What settings for the non proof grade paper can I use? Or is the paper not recommended?
Absolutely! You should probably start with the 80 lb cardstock settings in the Proofgrade dropdown menu, and do a little test cut. If that doesn’t cut all the way through, switch to manual settings and start reducing the speed a little at a time until it consistently cuts through. You can save these manual settings so you can use them again anytime you cut construction paper in the future.
Adding to what @cynd11 said, on the Aura & Spark the color of the construction paper may make a difference, especially if your design includes crease/fold lines. Cutting is usually straightforward, but testing is very important. Luckily, construction paper is inexpensive.
When it comes to cardstock in the Aura, I’m finding that thickness makes more difference than color. Your mileage may vary.
And I don’t recommend stacking sheets of paper. Cut them 1 piece at a time.
Never leave the laser when cutting paper.
