I know many people have stated you have to use the right acrylic in the Glowforge. What about size? Is it possible for the GF to cut and design this? The size is 36x24.
I run a photobooth business and my clients always as for this, one for Facebook, Twitter, and Snapchat.
No the gf basic will have a working surface of 12x20 and the pool 20xinfinity(with proposed pass through). However maybe your design could be in multi part and assemble
This is a question I think we should be able to answer, but information is sparse and scattered at the moment.
As @Clone mentioned, the Pro model of Glowforge has a cut area of 12x20", so with that you should be able to do objects 20" wide by ∞" long. So, 36x20" should be quite doable with a Pro Glowforge.
Many machines have a bed that’s larger than the cut area, so it’s possible that there will actually be some extra room for larger material. For instance my non-Glowforge laser cutter, which has a cut area of 12x24", has a little extra room on each side (about 2" on the left and right, about 1" in the back, and about 0.5" in the front). Larger material, maybe up to 13.5x27.5", could be shoehorned into if it was absolutely necessary. Maybe there’s a similar amount of extra room in the Glowforge… we may not know for certain until Glowforges start being delivered.
Have to point out the 3x5 blocks. I guess that printing some using layers of acrylic with the Glowforge will be possible. Would be interesting check for tolerances.
Sorry for the confusion. The handheld ones are strong and I thought it was acrylic. I just learned it’s PVC which can’t be used. These larges signs I posted are cardboard. Sorry for the confusion.
Maybe whiteboards? Admin could remove this. Not trying to advertise or anything. But these are the small ones. Heavy whiteboards or corrugated cardboard could work.
