I bought these key chains from Michaels[Key Chain]
(Rectangle Sublimation Keychains by Make Market®, 4ct. | Michaels)
Can engrave on them? If so what settings should I use?
According to the product description, it is mdf which you can engrave. With any non Proofgrade material, you may have to do some testing to dial in your settings. A good place to start is the setting for medium draftboard.
If you have the Aura, Glowforge does not recommend engraving/cutting mdf.
Considering the design, you can make your own much easier. Have you already sone the sublimation?
