This may seem like an odd question, but can I control the power to my Glowforge with a smart switch? So that rather than turning it on and off, I just cut the power to the receptacle and keep the switch in the on position. Would/could that cause any damage to the internal power supply? Thanks!
Yes.
Yes to which of the two questions actually asked?
Is it yes to the first question if itâs OK to use the smart plug?
OR yes to answer the last question if it can damage the internal power supply?
(I suspect yes, itâs OK, as long as itâs not also surge protector, right?)
There is no harm in using a surge protected power strip or power supply, although the manual says you should plug directly into a wall outlet solely for legal reasons.
Yes to using a smart switch as a means of turning the unit on or off.
Since the unit has a hard switch which kills all power and it does not require âsafe shutdownâ it should be fine.
I would just add to be sure and use a relay or âapplianceâ type, not a dimmer.
Thanks!
Thanks! Oh, legal speak. Not as bad as the manual for an electric lawn mower I just bought and on the second page boiler plate info it lists âDo NOT use outsideâ. Did I miss a trend to grow lawns inside?
Thanks for confirming!
Yeah, Iâve got a non-legal recommended wemo insight on mine. Been fine since I got it. Remote access to let updates run when notices are released and ability to turn it back off too.
Yep, for convenience I have both my inline fan and GF on the same smartplug, connected to my Alexa.
âAlexa, turn on Luciferâ is my call to action
As long as the contacts in the smart plug are rated for the amount of power the machine draws it would be fine. it would all be based off the relay
Got mine setup for âTurn on the Glowforgeâ for both fan and machine, seems I may need to up my smart plug name game ![]()
Yes but does Lucifer turn on Alexa? I can just hear the sound effects now.
Lucifer = Light Bringer = seems appropriate for a laser.
Want I wanted to do was call it Goldfinger and program Alexa to respond with âDo you expect me talk?â but I couldnât make that work
