Can I use Med. Basswood plywood (proof grade) to run camera calibration?
It calls for medium Draftboard but I don’t have any on hand. I do have the proof grade medium Basswood Plywood. Will that work?
Should be fine. I think i’ve seen people use cardboard for calibration.
Yep, @kanati’s correct. You can use any medium thickness PG product.
Thank you!
Thank you very much!
Anything that is flat, flat and flat and you can score. So think tannish in color and flat.
If you have a roll of masking, you can just re-mask whatever you use and do it again. And again. And again. I’m not saying you’ll have to do it more than once, but if you do.
Thank you for the tip!
