I built my kids a new treehouse three years ago and I kept all of the redwood from which it was built. It was stained once upon a time ago, but it’s pretty distressed now. I was thinking these planks would make perfect signs for the GF.
I have been busy doing copper wire tests on various materials I have laying around that will eventually get put into my cutter (or tossed far far away).
For the various woods I have been examining this.
There are a couple of caveats you should be aware of – it may char easier than some other woods, and deep engraves may produce more gummy residue. And if you have anything that’s pressure-treated you might want to do some research on lasering it.
You’ll have to remove the crumb tray, prop it up and then do some math to obtain your focus height. There is a thread around here about that. Also, maximum length with be 20 inches so some of those pieces will need to be cut down. But are you crazy? Of course you should laser it (assuming no weird treatment has to be done to wood before importing it into Hawaii.)
Thanks everyone. Most of those planks are 1/2", some are 3/4" thick. I’ll experiment with some throw-away pieces to see how it behaves. This wood is really dry, so I don’t think there will be much residue but I don’t know what I’m talking about lol.
I might cut some of those in 1/2 to make it go further; I would just need to distress the wood on the ends where I cut it. Woodcraft sells this stuff that distresses wood (basically just rots it and dyes it at the same time) that I may try on the ends.
I figured I would just stay far far away from pressure-treated/borite-treated framing lumber. Home Depot sells cedar “dogear” fencing pieces that are very inexpensive that I may play with. They’re not treated so it should be ok.
I have the Pro model coming, so the 20" limit is one I can work around.
