Is the GlowForge capable of cutting the non-adhesive edge of a pad of post-it notes (or other brand)?
Example: see #3 in this image: https://www.imprintitems.com/userfiles/files/small-Die-cut-shaped-post-it-notes(6216).jpg -
If answer to #1 is yes, is it capable of cutting through the adhesive area?
Examples: see #1, #6, etc. of the same image
Technically yes but you dramatically increase the chance of fire, stacks of material generally don’t go well. I wouldn’t risk it personally.
Even if the stack were to survive, it would be a sooty mess. What you’re seeing in that image was done with a die, basically a blade under pressure. Clean, no destruction of material. Best tool for the job.
