This may sound weird, I did a forum search but didn’t find anything. I normally soak my crumb tray to clean the gunk out of it. I was slammed over the holidays and haven’t had a chance to really get it cleaned. Is there any reason that anyone can think of that I couldn’t just take the crumb tray to a self serve car wash and power wash it out?? Not with their chemicals, I’d probably take my Simple Green spray bottle with me.
I don’t see why not,just make sure to dry it completely so that the iron parts don’t rust.
I always take it apart when I soak it so I can dry it so that was the plan. Thanks!
There are several places that there is no technical reason for cleanliness, though a laser tube full of gunk looks bad. To a degree the crumb tray is even more so that a very gunked up tray would not be a problem, It is iron for the magnets to work so rust could become an issue but everything else is plastic or stainless steel so I would not expect a problem as long as you are not using bleach or other such chemical that could bond, but drying it quickly and well I would guess to be the larger problem
It’s gotten to the point where some of the junk build up starts to smoke which worries me a little. And sometimes gets on my more delicate items and makes a mess. It’s just that when the crumb tray is clean I have to do less clean up on my projects coming out of it.
And I’m anal retentive about my GF being clean.
For reasons to see what the head fan was doing I created a large 1 pew engrave on a empty tray. It would certainly clean any area of the crumb tray that it passed over as well.
Now there’s an idea … but it wouldn’t get the entire crumb tray? Most of it though. Interesting thought!
I’ve put down masking straight on the tray before to serve as a jig. Not necessarily recommending it as a full-time thing, but could be good in a pinch to cover a messy tray or preventative if doing something especially mess-making.
Way back in the day of silver crumb trays @karaelena disassembled his and soaked it in a simple green solution and it came out looking new.
Limited Edition if you please ![]()
I have not cleaned my crumb tray (other than dumping the crumbs out of it) since I got it. I’m only considering cleaning it now to maybe cut down on some of the smell from the many months of burning things. But still considering, not actually doing at this point
Yeah, it kind of hurt sending it back with the PRU they had loaned me.
Wish I had kept mine, the contrast helped visibility on the bed.
This is what I normally do but because I’ve been so busy I was looking for a faster alternative. I’m thinking spray it down with simple green, let it sit for an hour and then power wash.
I was going to ask about disassembly, but I feel like there was a post about this.
Oh yeah here we go, @karaelena posted it:
yep this is the method I normally do. Just looking for a little bit faster turn around.
Hmmmm…looking at that it suggested to me that we of the black honeycomb tribe could get those nice edges defined by spraying the whole thing silver and as we lasered it off via cuts over time we’d get the same nice borders…hmmmm…
Magnets stick to the honeycomb pretty good, so it’s not made from high-grade stainless steel. It’ll rust. I don’t think it matters much how you clean it, it’s pretty robustly built and very little will attack the metal. I just took it out to my driveway and used my pressure washer. But since I used water, to avoid the risk of corrosion I blew it dry with compressed air when I was done. A hair dryer probably would have worked as well… A little rust isn’t going to hurt it either, I don’t think. It just looks crappy. Though who knows, maybe the laser will scour any rust. I remember seeing a video recently for a hand-held laser that did just that, taking the rust off metal, literally making it disappear instantly, no elbow grease required.
Don’t know how I missed that post, but it was AWESOME… And you definitely need to do the soundtrack with it!
