Does glycerin evaporate without residue? (Chem not my strong suit)
Not for a long, long, long, long time. You would just wash it off. Itâs soluble in water.
Itâll wash of easy like soap and it comes in food grade. - Rich
So would it interfere with the lasering process? Bubble? Spatter? The soap dries, so it would be different.
Weâre talking thin coat. I havenât tried it, but I would bet it would be better than using detergent that is designed to make loads of suds. Just sayinââŚMy advice is worth exactly what you paid for it. - Rich
Will definitely be following this! Iâve tried the Moly-D spray before with some success but it was time-intensive on the laser. I thought about cutting a mask on the metal part, spraying the Moly-D, removing the mask, and hitting it with a torch to âbakeâ it on. But, once @smcgathyfay does her tests, weâll know better!
Just got to the office to have a look at my can of Thermark.
Ingredients include acetone, ethanol, propane (spray can propellant), molybdenum TRIoxideâŚnot DIoxide, crystalline silica, mica, iron oxide, manganese and nickel.
I have some ideas on different mixtures to try that might work.
Any chemists want to collaborate with me? I got an A+ in Chem but that was 30 some years agoâŚlmao
I will apply with both airbrush and sponge. Hope to find good results
I donât think Chemistry has changed much over that small period of time
But oneâs working knowledge of it might.
I jokingly said the same thing to my girlfriend, who spends hers days in a research lab working towards a PhD in immunology (published article here: Risk Factors for Autism). She told me I was wrong.
The âEtherâ and Earth are no longer considered elements.
HahaâŚthatâs fair.
Of course, I shouldâve known better to make an over-generalized comment like that on here. Though some of it seems like just the table âlayoutâ is constantly changing. But it seems like the theory of âelectron-pushingâ, to understand how reactions occur, and electron orbitals havenât changed much, if at all.
Itâs interesting they add molecules that only last a few seconds after some atoms are smashed in a lab. And, that they now give a range in which an elementâs atomic mass can range from!
Exactly!! Iâm sure I have forgotten more than Iâve learned in the past 30 years lol
First test.
TM = Traditional TherMark
A = molybdenum dioxide made into a slurry with perfume grade isopropyl alcohol and airbrushed.
Doesnât look like the MD works as well all by itself.
TherMark has molybdenum TRIoxide as well as lots of other ingredients.
I can certainly see a difference in density, but with the price differential it is still great for marking on metal. Perhaps not for commercial purposes but I would be satisfied for my garage uses.
Thanks for the test!
AlsoâŚ
http://www.ebay.com/itm/molybdenum-vi-oxide-99-5-100g
did you use dioxide or disulfide (which is what you linked to above as your purchase)?
I just failed Chemistry!! The original post was using molybdenum disulfide and yes thats what I was using for the test. I will edit itâŚthank you!!
Probably because thermark is more like enameling than engraving: http://www.thermark.com/content/view/16/86/
love this. I also searched alternatives and found Dry Moly as one of the b best alternatives. But it is so messy. My project for it is small so using a paint brush is exactly what I need. Love this. going to buy a bag and try it! could you possibly send me the link to yours, specifically? with all this counterfeit stuff going around (and Iâve been duped already) I much rather use your source since youâve proven it is the real deal. Thanks!
Me too.
But I notice that no one has considered saving the washings, and re-mixing them, if their cutting the cost to the bone !
