Hi, what do I need to change in my settings when the cut doesn’t go all the way through? Speed or power or both?
Click on #6
After making sure your optics are clean and the material is flat on the bed, more power or less speed are the next steps. When I have issues with not cutting all the way through, it is more often than not, the lack of flatness.
The entire First Prints section is priceless, but this will give you an understanding of exactly what you need here:
Interesting point. As you can see some of it worked. if the board is warped, do you have any suggestions?
Thank you that’s very helpful! And some of it more than I knew the machine could do!
search the forum for hold down pins or magnets. Either work to help get the sheet flat for cutting.
