First time ever cutting acrylic (3mm smoked one) so I used the settings found on the excel for “clear” as a base on a Glowforge Pro, aka speed 125 and Full Power.
It did cut fine but I can notice on the borders that the grill “transferred” to the acrylic so I assume there was excessive heat?
Why wouldn’t you use the Proofgrade settings for medium acrylic, which for my pro is 170/full? Your speed is much too slow, and you are getting flashback.
It doesn’t have to be proofgrade material for you to use the drop down menu and use one of the proofgrade settings. Those settings have been specially calibrated to work the best with those particular materials. I suggest you begin with those and I’ll bet you never go back to the way you’re doing it now.
The PG settings can sometimes result in a bit of flashback on naked acrylic. The paper masking that comes on PG acrylic helps with that.
If you don’t have any masking, or don’t want to deal with peeling it, a sheet of copy paper between the crumb tray and acrylic works nicely.
