Claw Clip Hinge Help
Hi all!
I’m really wanting to craft some cool claw hair clips. I’ve tried to find various hangers for the clips to no avail. I’ve seen these clear hinges glued on acrylic as a solution but despite desperate attempts to locate just the hinge for sale I’ve had no luck. I’ve tried google image search and typing all sorts of variations of descriptions but no dice.
Does anyone have a link to purchase these clear hinges for claw clips?
Thanks!!
Edit: adding per someone’s comment that I’m looking for the entire assembled piece (hinge and spring).
It’s called a torsion spring and you might find one here: McMaster-Carr
Perhaps they were asking about the entire hinge assembly (clear acrylic + torsion spring) rather than just the spring…
Yes this is correct! Looking for the whole piece!
I don’t think any kind of adhesive is going to be able to bond dissimilar materials well enough for something like this. You’d probably be better off simply making decorative pieces to attach to an existing cheap clip in a way that little stress is applied to the join between them and the clip.
Your next best bet is likely going to be joining a jewelry/fashion accesssory discussion group of some kind.
Hrm…looking at one I have at home, I think you could cut 90% of these yourself out of clear acrylic. If you are a careful adhesive user you may not need the clear crosspieces.
