I just got some Columbia Products wood and wanted to test cutting it, and I also had a design I wanted to test as well. So here you go.
Rather than post the design files. I will give you the link to make your own.
I then had to modify the front and back pieces to sandwich in the acrylic. If I were to make it again I would shorten the living hinge to account for the extra depth from the stacked pieces. Also add a better way to get the money out, right now it is friction fitted to just pull it apart.
The green is boxes.py, the red is what I added to get the results in blue.
Side view
