Colorvideo
Not sure what “pretty different” to each other means as a hex number. You can’t get more different than 2 different numbers (kind of the definition of different). So 2 colors, even if only by 1-bit is as different to a computer than all 32 bits being different. (and before someone snarkily comments it’s only 24-bits, I always count alpha…). As for the colors being in order. well only if you want the GFUI to default to a specific order. Since you can drag/reorder at will I never care and simply manually realign rather than take the time to load a custom pallet…
