We haven’t finished thermal profiling yet. The Basic is designed to use passive cooling (pumping water through an aluminum block) to run at room temperature (around 70 degrees); The Pro is designed to run hotter and longer. I will share hard test data with you as soon as I have it, but that will be a ways out. You will, of course, have a chance to cancel or change your order when we release that.
