How do you copy from one inkscape file to another while keeping the vector qualities?
I have an SVG, and when I go to copy the design into a new file (using the copy and paste on the inkscape menu bar on a mac), I get a bitmap version of the vector in the new file. Is there some extra special version of copy I should use? Duplicate only seems to duplicate within the file.
Does the original version of the file contain a bitmap as well as the vector version?
What I do is just open a new file, tab over to the original and do a CTRL+A and a CTRL+C, then hop back to the new empty file and CTRL+V to paste it in.
Huh! You might need to convert any shapes created using the Rectangle or Ellipse tools to Paths. (Also text.) I just copied over a couple of tests, and they came over as the originals did, but those still need to be converted to vector paths. (Path > Object to Path).
That’s the only thing I can think of unless there is some sort of setting somewhere in the Preferences that automatically converts it.
Forget about the original file. I get this to happen on 2 freshly created files. I can’t copy vectors between them. Is there some setting I may have changed?
I’m sorry, I’m at a loss, I hope someone shows up that can help. I looked through the document properties (PC) and nothing. I would think that the Mac clipboard is at least as smart as the PC’s?
Thanks, @evansd2. First for letting me know that I am not alone. Second, following some of the links lead to a workaround: a prefs change in Xcode. Now it works normally. The apparent downside is that I won’t be able to copy outside of Inkscape (or any other X11 program) to a mac program.
