This is 1/4" non-PG masked clear acrylic, engraved (from the back) with a defocused beam. Only a few pieces developed these horizontal streaks; most have a consistent, frosted look I was hoping for.
Is this due to too much power? 1000/Full (Pro), 270 lpi, with a focus height of .4 inches.
That is not “crazing”. That’s just the nature of acrylic for solid area engraves. Acrylic gives you a very “precise” representation of the path of the laser. Turn the design 90º and the lines will be rotated.
You can work around it with higher LPI, or more extreme defocus.
The laser vaporizes material. For many materials, that point is large enough to overlap the adjacent path. Acrylic just allows a much smaller point. So you can tighten up the path spacing, OR widen the point (defocus.)
