Or a mid-sized paperclip that is straightened out (make a little - like 3/8" - hook on each end so the pointy ends don’t end up poking your face). They can be reused so you don’t need to go buy a thousand of them & causing a new paperclip shortage
If you have scraps from your frog the measured width of the stiffer ridge of your nose and slanting out some getting thinner til bead like at the tips only the ridge itself would be the limiting factor. looking at the nose part of a pair of eyeglasses should also tell the shape but should extend further.
