Creating Stitch Holes in Cutting Patterns
I had to do this yesterday and found a great solution for Adobe Illustrator. I’m transcribing this from memory, so please correct me if I get the details wrong.
  1. Create a small circle
  2. Give it a stroke, but not a fill
  3. Select the circle and create a scatter brush from it
  4. Set the spacing to something like 400%
  5. Apply it to the path
  6. Edit the spacing to suit (e.g. to make it start and end with a hole, bump it in 1% increments)
  7. Expand appearance
  8. You will have both the path you want and a second path that has no stroke and no fill behind it. (?) Select a circle, send to back. Click on it again to select the invisible path that was behind it. Select…Same Fill And Stroke, then delete to be rid of them all.
    Print!
