Curious on the first pic, is that a T-Ruler? Looks awesome and of course
I need to crash but gotta save links first
Yes! do this right and you can mark/place stuff down to a 64th or so.
Crashing now, but thank you. Gonna make this in the morning.
I printed them without the skin bc i forgot to turn they layer on. Once they were burned, the tray wouldn’t sit flat. It seems as if my tray is about 1.5mm wider than the boots will allow.
I also noticed that the silver bare metal strip on the far edges also made the boots sit at an angle.
I created a v3 as a test. I adjusted for the bare metal strips on the outside and took a little off on the inside. It fit but i need to adjust it more and try again bc of the kerf.
Is this something you dealt with or thought of when working on the boots? I would think the trays would be pretty identical. Even closer than a tolerance of 1.5mm.
I will use the skin on the final version. If a smaller version works for me, I’ll send it to you for approval.
I’m sure they alter the machine’s construction over time, so your machine is probably a newer revision. It would be great to have an alternate version available for folks with a machine like yours. Tweak away!
