This isn’t really a problem that I’m having, it’s more of an observation and question.
Why isn’t there a switch in the UI to say if you’re using the crumb tray or not?
- Flip switch indicating the crumb tray removed.
- Popup box asks for material height input
- Another popup gives you the correct height spacer you need, or maybe you don’t need to set the right focus height.
This would be a simple program change, and I say “simple” because I’m a programmer and not because I just think it would be something simple to do. I could make that change in any of the UI’s I’ve developed in my plant in less than an hour. Of course, there is probably a QA process to validate the change, so it would take a couple days, but this is super low hanging fruit that could make some peoples experience with the laser much better.
