I finally have received my glowforge. But it has been delivered without the accessory box. Hence, I wanted to understand if I can use it without the crumb tray. I read on earlier post that you could use construction paper instead of the tray.
You should wait, the accessory box is shipped separate and will be a few days. Using it without the tray without understanding this risk will damage it.
Sure - most folks end up doing it a lot when they graduate to materials 1/2" and taller. Just stack up enough scrap or something on the bottom of the 'forge that leaves your material within a 1/2" of the lens. The stock crumb tray stands about 1.4" above the floor - so that’s the “0” height of the bed and the 1/2" height is measured from there.
Just do a search here - lots of posts on cutting taller material or things over 1/2" in height that explain the whole process way better than I am.
If you feel really nervous, you can put that construction paper on the bottom of the 'forge so it covers the shiny aluminum sheet to prevent reflections.
So I used the glowforge but we didn’t use it for anything cutting or scoring. I started with engraving , I was quite happy with the results. . Thank you to all so much
I used 2 plywood of 12 mm each and covered it the black construction paper and first tried to print on my MacBook. The results were quite satisfactory.
