Cut/Engrave slots into a wood base
Cut the slots from one sheet of wood (e.g. print the design you attached), glue it to a second piece of wood as a base. The depth of the slots are then the thickness of the top piece of wood. Does that work for your project? 1/4" wood will make a deep enough slot to hold up a lot.
