Referring to the lighted snowflake design Federico showed us on the last live stream: When design is uploaded is there a way to separate the 3 outside cuts, (on the left: Cut Ignore Score) because the design uploads together and the middle layer is out of a acrylic material so that has to be a cut when I switch material is “boxed” in with the top and bottom wood pieces. Hope I’ve explained this so someone understands😂 Thank you
Can you be more specific about which design you are referencing? I know that there are Cuttle live streams featuring Federico, but that isn’t Glowforge.
