If you have an image you want to etch, is there an easy way to put a cut line around the image in inkscape that follows the shape of the image in inkscape?
Yeah, you can use the Auto-Trace to create a vector of it, then break it apart and just keep the outside cutline. (I believe it’s Path > Trace Bitmap in Inkscape.)
https://inkscape.org/en/doc/tutorials/tracing/tutorial-tracing.en.html
This technique can work well for images as well as vectors…
I just made this cutline using it…
I did need to play with the fill thresholds a bit…
I added padding to the outside line using Path->Outset and the inside lines using Path->Inset
Thank you! This is great!
