I am trying to cut out the Architect’s Adjustable Table Lamp with 1/4 inch plywood. What settings will cut through it? Ihave tried several settings and still not getting it right.
If you search the site here you may find a lot of articles on cutting plywood that can help you out.
Are you using Proofgrade plywood? If not, try the setting for thick cherry plywood.
I had to do 100 pew pews at 200 zooms for 3 passes to get through 1/4" veneered plywood that I bought from a big box store. There may be better settings, but after a bunch of testing… this is what worked for me.
