I was trying to practice cutting a slot and this is was my first attempt. I used the same settings for baswood but this is pine. The settings were 750/full power on the engrave option. I thought focus height represented the depth so I set it to 1/2". Pine is a lot harder than basewood so I thought the baswood settings would be a good for a test run but…nope.
I set the line image to go all the way across to each side…but had an error message about the thickness of the wood (it’s .75" and I had the crumb tray out already). I put masking tape across the top and let it barely hang off the edges which got rid of the error message but the GF did not go all the way to the sides.
I needed to cut an 1/8" or 1/2" slot for an acrylic plaque (1/8" thick).
I included an example of what I was trying to achieve.
I attempted to make a slot with a reciprocating saw a few weeks ago and it wasn’t working. The thickness of the saw blade is not thick enough for the width of the 1/8" inch acrylic.
I hope someone can help me figure out the setup. Thank you.
