Hello,
I am trying to find settings for engraving and cutting 1/8" polycarbonate.
Thank you
Hello,
Thank you
Have you tried search? There’s heaps of info on PC — mostly recommending not doing it due to melting.
I have and some say it works you just have to adjust settings but I can’t find the settings
Testing is the only way to dial in a non-GF material. ![]()
Polycarbonate likes to discolour, so fast low power settings work best. It will also depend on the thickness, this is a good place to start - but expect to test up and down by levels of 5 to find the perfect settings for your machine.
(don’t worry about the adding radii to the corners, as
fixed that)
