How do you cut a name out. Every time I try, it cuts out the letters individually. I’m using illustrator for the fonts. It looks good when I save it, but then I go to cut it and it shows each individual letter
In Illustrator:
Select the Name, click on Type > Create Outlines.
Then select the outlines, click on Unite in the Pathfinder palette.
Thank you very much. It came out perfectly
