Need help as i am lost ( imagine that, right). So what i am trying to do is to get name tag from wood, it engrave name but unfortunately i can’t select CUT like rectangle around engrave name, no option. I know i am doing something wrong, question is what?
Thank you all
You need to add a rectangle around the name in the program you created the name in. It should be a vector object with a stroke and no fill.
ok let me try that, thanks
Then you should see two operations in the GF UI - one for the cut and one for the engrave.
