Jules
April 20, 2019, 11:23pm
Congrats!
If you use the back key to go back to the Dashboard, there should be a separate file listed for use with the acrylic. (They break them up into material used.)
The Dashboard: Sign in to app.glowforge.com
[dashboard]
Keyboard Shortcuts and Maneuvering in the Interface:
Copy (Select item)… CTRL/CMD + C
Paste (Select item)… CTRL/CMD + V
Undo … CTRL/CMD + Z
Delete (Select item) … Press the Delete key on the keyboard.
Update on Delete: _After the Autosave Settings Saver migration on 01/08/2018, if you delete a part or item from your file it will stay gone when you close it.
The next time you open the file, it will not be there.
If yo…
