K
image|373x500Give the disk a spin and see what fortune favors. The material is called candle stone. Very similar to corian. Basis is made of 1/4 birch ply
Took the engraving well.
I’ve used he material before on a CNC making lithophanes.
Came out great! I like the zen-like simplicity of it.
What did you use to make it spin?
Very complex system. My finger.
At the points where it is connected to the base, what did you use for that?
1/16 x 5/8 metal dowel pins, found on amazon. Drilled using a Drexel and a drop of CA glue in the hole
Thanks for sharing! I hadn’t been exposed to candlestone / corian or lithophanes, but now I want to make some!
