I have been playing with Deepnest to arrange wooden letters I need to cut. When I import them into the program they are smaller than they are set up in Illustrator. For instance 5 inch letters are only about 4.5 inches in Deepnest. Has anyone had a problem with scale and is this a setting thing in Deepnest?
I had this same issue. Check the Document Properties (file menu) and make sure that the scale is set to 1.0. Mine was at .26 so everything showed up at about 1/4 the size I was expecting.
Also, make sure the pixels per inch is set to 96. Inkscape used 90 for a while, but switched to 96 in recent releases.
0.92, to be exact.
I assume the document properties are in Inkscape? I am using Illustrator. Its strange because if I open the SVG in another program it is scaled properly which makes me think its on the Deepnest side that something is not quite right.
This topic was automatically closed after 32 days. New replies are no longer allowed.
