This is why I continue to read the forums. Stuff like this that wld take me ages to figure out on my own, thx so much for sharing your findings @takitus. Is there a difference in length of time, if any, between focused(?) and defocused cuts?
It was just the engrave that was done unfocused, but there wasn’t any time difference at all. Just a big difference in surface quality =)
That is really amazing!
This is going to be a stupid question, I’m sure, but would this help other materials such as wood? I assume it works for acrylic because it melts, but could defocusing on wood give a smoother, more even burn too?
It could potentially help as the defocusing of the beam would cause it to have a larger spot size which would cause the ablated areas of each pass to overlap. I haven’t tried it but I think it could potentially work.
Wow that’s a far nicer result than usual. I’ve always been pretty uninspired by acrylic engraving because of the resulting texture so this is great to see!
Does it make any noticeable difference to the edges of the engrave? Technically it should slightly increase the kerf and round off the edges but I don’t think you’d notice in practice
Thanks for asking that…exactly what I wanted to know, as well.
Wow! What a difference! Thanks for this post. I’m just dying to get my Pro model, but these posts help so much.
it really is an absurd difference; nice find.
How did you arrive at 0.433" ? Is that the highest it will go? I thought that would be 0.5".
Yes, the tips, tricks, ideas, troubleshooting and then posts where to source materials are incredibly helpful. Plus lots of fun banter. One of the best forums out there
Holy cow, what a difference!! Thanks for sharing the results…a defocused engraving is something I’ve only ever done accidentally
Awesome! Any issues due to the larger spot size?
The manual focus and height levels can only be set to that at maximum currently. I am unsure how far the autofocus will go as there is no readout for that, but have engraved/cut thicker items than .433".
None at all! If it was really too much of an issue you could always run a score around the edge of the engrave to clean it up a bit
That’s a surprising, but very exciting, difference. Thanks, as always, for sharing your tests!
Could you do a vector around the edges?
That’s really amazing (and a lot like the engraves we’ve seen on other machines – maybe the GF optics are just too good?
It’s interesting that this is considered defocused engraving when the result is so much better. I would consider this proper focused engraving. hahaha.
Yes it is actually pocketing by raster engraving, so you want a flat base and don’t need a high LPI.
If you wanted fine detail then you might want sharper focus and higher LPI.
Discord doesn’t like Rocky Horror jokes I guess, because it asked me to put in a complete sentence.
THREE
MORE
TRIANGLES
