Hi, I am planning and designing an acrylic box to store all my nuts and bolts in different sizes and individual spaces. But I have no idea how to design a lock for the lid. Nothing complicated or fancy, just to keep the lid close if the storage case is sideways. I am strongly influenced by the fishing storage kit.
There are many, many options, from hardware available for small boxes to two pins and a rubber band or cord. Can you provide any additional detail on what you would like to see?
I have used magnets, box hardware, over-center latches, pin and loop latches, button and cord, etc.
I would probably use a small hasp to keep it closed. That should be pretty easy to get and will be reliable.
I would look into pre-made boxes for beads, etc. Those will likely be more cost effective in the long run and have the hinges and latch already included.
You could take a look at the treasure chest I remixed from thingiverse for proofgrade, that hasp works pretty well, and might inspire you do come up with something.
I use that first one a lot. I thought about making trays but the cost of materials (not to mention my time) far exceeds what these cost from Amazon or Harbor Freight.
Personally, I run into the situation of a unique physical space that does not allow me to use a cheap, off the shelf solution. So I have to decide between suffering with the world as the way it is or spending an inordinate amount of time designing a ten dollar thing. That said, there is no reason to spend any more time than necessary, especially on a utilitarian object. Find an off the shelf clasp, closure or whatever, measure it with your calipers and cut some holes in your acrylic. Then use a small bolt and nut to attach your locking mechanism.
