I attached the file, in illustrator I embed the graphic, was a PNG file. used the draw inside feature to create a clipping mask to easily have the design only where I want it.
However when I upload the file it removed masks and converts to paths and the full image appears.
How can I not use clipping masks but have the same effect of putting an image or pattern just on the piece I want to cut out
In Affinity Designer, once I get the image clipped the way I want it, I rasterize it. That creates a new bitmap without clipping paths. No idea if AI has the same sort of thing, but I thought it was worth a try!
I believe I found a fix. I cropped the overall mask to the size of the piece, engraves a little bit in the wasted space between pieces but if anyone know how to make this clean and simpler that would be great for future reference
The Glowforge interface does not handle clipping paths. You can rasterize the image with the clipping path to create a new raster image, but for something like that, you can also just let it engrave the whole thing…it’s not going to add much time to it and the overlap is in the waste area.
Ok I see. You can’t use clipping masks as far as i know. But you could leave off the clipping mask and just let it engrave into the waste since your actual cuts will be clean through the overlapping engrave.
Not sure if it is the same in illustrator but ive dont the same thing in inkscape, and afterwards once i get the image the size/ shape i want i then export it as a png and then re import it to the design
The forum software automatically strips any images out of svg files. If you want to upload an svg with an embedded image its best to zip it first and upload the zip file.
