I took some time this afternoon to do a live stream of making a box start to finish with OnShape. This builds on some of the stuff from OnShape Lasercutting Workflow. I’ve picked up a few tips and tricks over the past couple of weeks and thought I’d share.
Great video, I hadn’t seen the kerf or layout scrips. For anyone having trouble with the dxfs I’ve found PDF export instead of dxf is a little more reliable for me. DXF only supports circular arcs so if you have any beizer curves the dxf will be corrupt.
