Can I use Microsoft word to design things to cut out. I bought sag files from Etsy and would like to cut them out.
I use Word fairly often. Powerpoint works as well. Just save as a PDF and you are good to go. Make sure that things you want to make different operations are different colors so you can select in the GFUI.
