You need to stop looking in my brain. I have been thinking of something very similar for dungeon crawls (six sided and scaled a bit bigger for miniatures.)
Very nicely done sir. Now I really cannot wait for my GF.
Yes those Catan tiles fairly screamed the idea for an interactive dungeon crawl that each player could add their own tiles like combining D&D and Magic the Obsession in a single game
Don’t pick that stuff off by hand! Use a piece of tape. Seriously, use some duct tape wrap in in a loop big enough to slide over your fingers (sticky side out). Makes weeding so easy and fast.
First peal off all the large connected pieces, then press the tape down firmly on any left over bits and peal up at a 45ish degree angle. If you find any particularly stubborn areas just apply and rip up the tape in quick successive motions until it submits.
You’d obviously need to be careful on any laminated materials or around any super fine details that might separate.
I wouldn’t say untapped exactly, there are lots of tile systems, ranging from simple flat pieces like these to fully 3D systems… here’s a laser concept:
I got these from your ETSY store…they are great. However, I had to decipher your instructions a bit. I had to load it into Illustrator to see what parts to score and what parts to cut. I did it on Proofgrade draft board for my first try. Your “light score” you have listed at 300 speed, 5 power…that didn’t even mark the top protective layer. I changed it to 300/25 and it did…but it was too close to the actual “Score” sections…next time I will try 300/20 or maybe 300/15. I also screwed up and left the last section of structures (bridges and steps and stuff" on “Cut”…they are still usable, but missing cool bits, so if anyone else is getting these, follow the directions for cut vs score. Well dont…I really like these a lot… I got both sets, so I should be good to game. Thanks.
