So I want to make multiple cuts of the same design. How do I copy and paste duplicates on the program.
Control/command C to copy and Control/command V to paste.
or click once on item, right click mouse / copy then Paste
I was trying the right click but hasn’t work. But the Control C and Control V did. Thanks both for responding so quickly. Have to make 25 and didn’t want to do it one by one
Thank you that worked.
You’re welcome! Enjoy the adventure.
So is there any way to lock a design so you can drag and drop it easier in place?
If you mean lock so you don’t actually resize, no (The undo command: Ctl (or command) z is your friend for that!) - but you can use the ruler in the lower left hand corner to move things via typing in a number rather than dragging…
