Does any kind person out there have a free sewing pattern for a dust cover available? I can sew well but I’m not very good at making my own sewing patterns. Thanks in advance!
A dust cover for what?
A Pro GF
AFAIK no one has posted a pattern, but based of the measurements on the tech specs page, and using the box generator I made the attached.
Obviously with cloth you don’t cut out the fingers, just cut straight across the outside and use the markings for the fingers as your seam allowance
It’ll get you started! (I added 10% to the measurements so it wouldn’t’ be skin tight, but you’ll probably want to make sure it’ll fit before you finalize anything).
You are fabulous @deirdrebeth! Thank you!!!
I ended up finding this pattern on Etsy:
https://www.etsy.com/listing/817678167/glowforge-cover-laser-printer-sewing
The pattern is excellent and I would highly recommend!
The attached pics took me about two hours to complete. It’s oil cloth. I decreased the seams to 1/4" instead of 1/2" and it fits like a glove!!
It’s a start…
