If cutting in a single sheet, yes, you will have a 19.5 x 11 inch space. I set up artboards in Illustrator as 19.5 x 11 to make sure I use as much space as possible, then just pack all my cuts inside it. However, if engraving, you’ll have less space depending how large the engraving is.
