This is beautiful!
That is the origin of the term “chiseler” that one could make a large profit by removing (with a chisel) tiny bits off each of a great many coins. Today they use computers buying and reselling stocks ahead of each trade getting as much as one percent of the price, of each but billions over all. the result is very similar
Interesting analogy, and spot on.
Honestly, I wouldn’t follow my example here. The more I look at it, the less happy i am with my settings. I think I burned it a hair too hard, the shadows lost more detail than I wanted. I’m redoing it right now at same power but higher speed and at a larger size (17" wide by about 8" tall, or 43x20cm – it’s going to take 2 hours!).
My material choice isn’t ideal either, using baltic birch ply. Plywood is sketchy for engraves because if you go too deep you hit glue+internal layers, which changes the look of the darks. While I’m sure that this can be used for good, right now it’s firmly evil.
When I get serious about a final version of this, I’ll probably find a nice blank of maple or basswood to do it on. I’d say to use proofgrade stuff, but it’s masked, and I’d want to get a good look at the surface before trying it, a knot will impact the final piece in a big way.
Besides, I curved this piece so that there is no true white anywhere, I find that the transition from “barely engraved” to “not engraved” is too harsh, so I put my lightest whites at something just under 255. This means that the advantage of proofgrade being prefinished is negated, because I’m ablating the whole thing. (hint to GF, sell unfinished and or unmasked proofgrade at a discount!).
So, in the end, about the settings: nah You don’t want any of this nonsense.
EDIT: I think it already looks much better, engraving dust and all:
Someone here had a fix for this. It was noticed that a bright light along the back showed voids or knots and you could mark the location on the masking so as to avoid it.
I have not done this yet, since I have no proofgrade (), but I have examined some unmasked stuff I was pre-measuring for thickness and the concept sounds valid.
Wanted to provide the link but could not locate it, sorry.
I actually found the Baltic Birch plywood had a better dynamic range than the Proofgrade stuff. I have a thread on my experiments with engrave settings here:
https://community.glowforge.com/t/an-engineers-perspective-on-photo-engrave-settings-for-wood/15042?source_topic_id=16035Regardiing the masking: add a score on top of your cut line, then do a GFUI run with only the score enabled, then you can carefully peel off the masking (the score will have cut through it) without moving the material, then go back into GFUI and enable everything except the score before doing your final run.
This will allow you to remove the masking just over your piece. If you don’t mind the extra score line, you can alternatively do this just around your engraving area.
I believe you mean this:
https://community.glowforge.com/t/trick-for-inspecting-plywood/15168?source_topic_id=16035Written by someone, as in by me
And yeah that might help identify knot locations on proofgrade too.
I seriously thought that your print was either a replica die stamp, or the real thing. Stunning, my friend!
The detail on that engrave is incredible!
You aren’t kidding. When I did it at 17” wide, this gem became apparent—
The corner of the Capitol building:
But, if you turn it so the light catches it correctly you see the mint stamp:
That’s just nuts.
Holy cannoli!
Gasp! Fainted…
Un-freaking-believable!
Beautiful engrave!
So what are the settings?
Ok, here you go, settings.
https://community.glowforge.com/t/settings-for-1-8-baltic-birch-engraving-and-cutting/16120?source_topic_id=16035Thx!
#necrogame
This deserves to be seen again!
Also, check inflation rates to what that should be worth today. Remember, it’d be a 5$ of silver in 1896, not just 5$ of …
I used to have a few sliver notes. Kinda wanted to find a gold cert to have but ah well.
Wow! Great definition. How did you clean up the charring?
