Engrave a skateboard?
Am I able to engrave on the bottom of a skateboard using the Aura?
… maybe? The tricky part will be getting it to fit in the passthrough slots. If you can remove the trucks and slide the deck through the slots I don’t see why not.
I’m so new at this—haven’t even tried to use mine yet. I forgot about the length issue. Not confident that it will fit in the slot. We’ll see!
It doesn’t even come close to fitting. Lol
You could engrave on self adhesive veneer and stick it to your deck…?
You could also cut a stencil and paint inside the stencil before removing it.
Another option with using a stencil could be to make a stencil and use a wood burning kit to engrave it that way.
