Hello I just try to engrave on the Glowforge Aura with a Light Maple Plywood and a prompt on the screen said “the settings are no proper for this material”, so Light Plywood cannot be engraved? Thanks, I still learning on the engrave think
You will always get that warning unless it auto-detects the material from the barcode. As long as you know you’ve selected the correct material you’re good to go
Thank you very much!
