I am just SO pleased how this came out! The details on the dress are amazing. I photographed my friends wedding and wanted to engrave my favorite photo for them. They were thrilled!
This is what the photo looked like before editing in grayscale
This is the edited photo I used. I didn’t want the black to engrave too much since there was so much. So I lightened a lot of the major black areas so the groom especially wasn’t too sunken in compared to the bride.
keep in mind that the engraving settings are only part of the equation. a lot of the time when we see poor engraving results, it’s because the picture is either not a good candidate or has not been properly prepared to engrave. mid-range grey tones, especially if you have a lot of them, engrave very muddily. you need a high contrast image to get a good engrave.
When you have a chance please if you could post original picture, if you then altered it the altered image used to forge. Also what material did you use and settings if not PG and did you bleed the image away from the cut?
Basically, engraving beyond the cut line so that you can be sure it extends all the way to the edges.
@rserrano7 - I’m not sure how @desireehobart did it, but the easiest way is to embed your engrave image into the SVG along with the cut line. Once it’s aligned in the design, it’s no problem.
