Hello guys,
Just wanted to find out if you think it would be possible to cut and engrave traffolite which is multi-layered phenolic plastic sheets. Tried to google around and saw mentions of it being lasered with CO2 lasers but yeah just wanted to see what you guys think
Cheers
If it’s not PVC (it isn’t from your description) then it’s probably ok to laser it, as far as plastics go.
The fumes wont be good for you, so get your vent setup on lock first.
Phenolic boards are notoriously difficult to cut, so be prepared to wrestle with settings a little to get it right.
For the clueless, like myself:
Traffolyte, sometimes spelled Traffolite, was a brand name for multi-layered phenolic plastic sheets suitable for engraving. Each layer was a different colour so engraved letters or shapes would be a different colour from the unengraved portions. Thus it could be used for name tags, labels and signs.
The material dates back to 1927, when it was first produced by Metropolitan-Vickers Electrical Ltd. at their Trafford Park factory in Manchester, UK for transformer labels. The complete business w...
I don’t know what result you can expect with the color angle, but it should be interesting.
As with all sketchy new materials: use your head and be careful of fire risk.
Just wondering how you got on with this?
Thanks
You realize this post is almost 4 years old? The OP hasn’t been active here in over 2 years.
