Engraving on Slate material settings
What material setting do you use to engrave on slate?
There will be multiple answers to any Beyond the Manual settings question, but search is your answer! Do be sure to read (or at least scan) through the thread because frequently the answer isn’t at the very top :smiley:
https://community.glowforge.com/search?q=slate%20%23beyond-the-manual%20order%3Alatest
Pretty sure I ended up using @danielle.r.richards’s (from @scooterdup’s post) with no shellac or anything:
I have engraved on dozens of slate/stone objects and have never found “one right setting”… I “work up to it”, and if after a few passes I see it’s not touching it, I cancel (open lid) then bump up the power.
I’ve done natural pieces I collected from various places, and “finished” pieces like coasters. The coasters and such were always easier because I’m just vaporizing the coating they had applied.
