I’m presenting at an upcoming conference, and I wanted some giveaways for attendees. I ordered some generic USB thumb drives on Ebay and decided to engrave my logo using the Glowforge. I made a jig and voila! It was surprisingly easy. And yes, the thumb drive still works - I checked.
What material are they made of? Anodized aluminum? or some type of acrylic? (I was nervous for you at first, because PVC popped into my head initially.)
They’re aluminum. Can’t say for sure if they’re anodized or painted, however the blue color is fairly durable and not thick like paint. So I suspect they’re anodized.
A suggestion:
Duplicate and layout each of the engraves in the proper places for the jig, then rasterize it into one big image. Instead on 16 front to back engraves, it’ll be 1 wide front to back movement.
Should see some significant time savings.
This is great advice. I knew my approach here wasn’t super-efficient. Was happy to simply get it working, however if I was doing tons of these, efficiency would be important. Thanks.
FYI - I did another batch of these, and the anodization wasn’t exactly the same thickness (same vendor, same product). They still turned out well, but had I tested first, I might have bumped the power a bit.
